AC stopped to activte fan and no cooling normally
Hello!
Noticed yesterday that fan does not start when ac is on and overheat engine (and ac stops work after a while) when standing still... tested to jump wire of thermostatswitch in radiator it starts then, worked fine untill this happend and fan never starts, before wasn't big deal thermostat switch never activated fan since ac did that enough to cool engine. What should i look for? Since fan works .. and have power.
felicia 2000 1.6
Edited by svenne1985
Hi there i have just broke a SLXi and th air con to put in my felicia L it could be one off the relays or a fuse in the black box buy the battery if this is any help to you
Thats correct was happenned with me and i changed the 40A fuze in that blackbox and every thing run normally.
