window stuck
Hi all,
Really need some help, I recently made a post about this before.
i have a problem with my electric windows and really need to source a way of fixing this.
i have a fault code if this can help someone to help me out.
0113 - interior monitoring sensor
36-10 - open circuit - intermittent
is this a sensor that i can replace??
if so is anyone break there fabia that i can purchase this from?
Please guy any help may help :):)
Its raining where i stay at the moment and my window is stuck down around 3" but i have a black bag covering it.
Cheers Gregor
Fault code is for the alarm interior sensor and nothing to do with the window. Window is likely to be failed lifter mechanism cable and regulator.
But both windows were working and then they both stopped, so are you saying that both regulators are knackered?
Regards
Gregor
also do you know where this interior sensor is located?
Interior sensor is inside the interior light assembly. If both windows have stuck, check all fuses, and if that doesn't fix it, comfort control module.
can i replace both of these? do you think this will resolve this?
Regards
Gregor
where is the comfort control module located?
cheers
