engine oil
hi guys
put the wrong oil in my car after service,didnt notice till after :wonder: 5w 30 fully synthetic,will it do any harm?i do a service every 5k
Yes, you MUST change it dor the correct spec. non-pd oil simply doesn't have enough scuff resistant additives to cope with the cam loads. You will knock a cam out in a lot less than 5k.
Change it as soon as possible and leave it to drain for 1 hour and don't forget the filter.
What type of oil did you use ? 505.00 spec?
