Vibration when moving Off
My Superb combi vibrates whenever I move off from 1st and 2nd Gear.....any guys know the cause?
DMF problems?
What sort of vibration? I would think problem with engine mount.
DMF problems?
DMF....what is DMF?
DMF....what is DMF?
Dual Mass Flywheel. The flywheel is not a solid piece of steel like most cars, it contains a plate with inner weights with springs to dampen vibrations. Sometimes those springs let go and the weights punch a hole in the gearbox bell housing. Was common on early (i.e. 2005) DSG gearboxen. If you like gory pictures google "MKV DMF failure"
I don't know if the superb has the DMF or not...
Thanks Wokwon for the information.....trying to make an appoint with the agent to check.
