screen wash capacity
Nice easy one I hope !
What is the screen wash capacity on my vrs ? I've run it dry as I want to refill it with Skoda's screen wash and I want to make sure I have the correct mix. I've decided against using cheap screen wash as my rear screen washer blocked up and after reading some of the stuff on hear about cheap screen wash, I think I'm lucky that it was a simple job to unblock it ! Yeah the Skoda stuff is dear, but I ain't taking any chances.....
If you have xenons 5 litres. Otherwise, I think the standard tank is 3 litres.
Just with Xenons or any with headlight washers?
I`m 99% sure you only get washers with xenons on the mk1? :wonder:
I haven't got xenons or washers, so I should be 3 litres...
Maybe, but this is the MKII group :yes: ;)
Any headlight washers - ie my pre-FL 4x4 that doesn't have OE Xenons
Tis a common upgrade amongst the non-washer brigade I am led to believe. But I've got xenons so I don't know any details.
You only get washers with xenons, so your screen wash capacity is 3 litres.
Matjaz
Simple solution:
Mix the screen wash in another container to the dilution you require then add to the washer bottle :thumbup:
Matjaz
4x4 and Scout get washers regardless of Xenons or not...
Yes, and the Elegance got headlamp washers without xenons too.
As far as the OP's VRS goes though I don't think washers were ever available as an option on their own, so only a VRS with xenons would ever have washers.
Simple solution:
+1
I mix it in a 5L container to the right dilution then add from that. Its far easier than trying to guess how much is in the washer bottle.
I've got washers without xenons!!
Read post 12!
The Elegance get's headlight washers even it xenon's are not fitted.
Edited by rustyGT
Filled mine from empty yesterday and it took a full 5 litre drum, xenons and washers.
