Show us your Yeti winter wheels
Yep, my boot's full of "work stuff" - around 100kg's extra - but on 9" wide Dunlop Sport Maxx GT MO which are almost bald when they are new, it's not rocket science to see why it just don't go in the Snow!
Dad's been out on all speeds now on his Goodyear Wrangler's on his Yeti and he's very happy so far - Snow has not yet been tested..
Al.
ps. tyres are not mine, but the same tread pattern...
Nothing beats winters on a RWD car of course...  but the sand in the back will help a tiny bit to at least get the car sort of going.
  • Replies 201
  • Views 41.2k
  • We all used to stop before the disc brake craze too. I remember ordinary tyres before the radial craze. Before heaters motoring coats kept people from the cold. One slither and crunch at walking pace
  • These are mine:     Same as the one's I'll be using in Summer because I live in Swindon, the extreme Winter weather we get is drizzle and sleet pretty much - same as in August.
  • Don't panic! I've been running winters every winter since about 2006. The michelins replaced two worn out Pirelli snow controls from a set of 4. Still got the remaining two on the back of the 500. Se
Cough, cough - well a 4x4 with winters will  :giggle:
You do know there is a plastic cap removal tool in the boot.
Yep, it was the cause of the problems - I would've been better with pin nose pliers
Really, I recon I could get all 20 of these caps off in less than 1 min with the plastic tweezers provided. A lot easier than using long nose pliers, and less chance of damaging your alloys.
Same here, I was really impressed as previous cars have been a pain.
Yes, until you stand on them and break them into two pieces, then its like trying to use chopsticks!
I was only commenting on RWD cars.   :giggle:
Same here. The plastic tweezers are dead easy to use.
Plastic tweezers? Every Skoda I've owned has had that annoying metal loopy hook device. A right PITA !!
Unless you let the tyre fitter do it when he's changing the wheels ;)
Winters on today for a tenner. :)
Autocar's winter tyre experiment:
http://youtu.be/7l2cMlNRX_A
 That should sell a few sets of winter tyres to Yeti owners, but the best option is still 4wd and winter tyres. Would have been good to see a 4wd and 2wd both with winter tyres also compared.
The metal hook is for removing wheel trims?
Indeed...  the metal hook has NOTHING to do with the plastic covers over the bolts.  NEXT to this in the foam box is a black plastic tweezer.  THAT is what you use to take these little blighters off.   :giggle:
There was such a test in a recent Auto Express (Winter Edition).
Nokian WRD3s, which won with a 100% overall score, were tested along with various other makes, on an indoor snow dome with a 30% slope, and both Ford Kugas (one 2WD other 4WD), got to the top of the 117 metre slope. Interestingly, the same 2 cars on summer tyres only managed just over 3 metres!
Overall the test proved that 2WD (FWD) cars performed better on Winters than 4WD on summers. But for ultimate grip then 4WD with winters (but not by that much).
Black steels with Good-Year Ultragrip 8's :)
Looks good with the red but you just need the Caddy centre caps to finish this off.   :rofl:
I was wondering what would fit but didn't like to ask so thanks for the suggestion :D
Just do a search on here for "winter wheels and Caddy".
Most people even fit Škoda badges like I did:
OR just read this thread:  http://www.briskoda.net/forums/topic/217147-black-winter-wheels-finally-going-silver/
or
 http://www.briskoda.net/forums/topic/180539-winters-on-steelies-to-trim-or-not-to-trim/
One from last year with a set of 16" alloys with Hankook Evo iCept W310s on.
Just had these put back on. I still like them...
So why have I not the tweezers?
Checked again today when the wheels were change and there is ONLY the hook.
Lee, mine looks just like that.
All you really need is a set of Skoda badges stuck on those centre caps.
One still has four steel wheels, winters and trims for sale if anyone is feeling left out.... :happy:
I don't have a problem with having winter tyres fitted as there are real benefits to having them, but I think if I get some I will have to fit them to my original alloys as I dont like the thought of paying all that money for a great looking Yeti then spoiling it for several months a year by putting little steel wheels on that in my opinion look pretty dreadful. I realize a set of 17" tyres will be more than 16" but I figure I will save money by not forking out for a set of steels or cheap alloys.
Plus the twice yearly cost of taking the rubber off your wheels and putting it on the other set - every single year??!  And you'd really rather do that to you alloys than just get a second set? The fewer times a tyre fitter comes near my alloys the better I say.  Believe me you will not be saving money going this route.  Buy a second set of alloys if you must but to change the rubber on your one set is financial madness.
Johann is correct. I bought some alloys and winter tyres for about £700last year. Swap them over myself in 30 minutes.
I get alloys all year round and it costs no more as the summers will last that much longer.
