internet won't load up after system re store
Did a system re store just to try and get a program back on I had lost, it never worked so re stored it again back to todays date, but now no browser will load up? EVerything else fine just can't get it to load. Internet connected just no browser. Tried another re store but now its not comin up with the re store dates, its just blank? Tried to solve a simple problem and totally cocked it up Lol browsers I had where explorer and chrome.
  • Replies 59
  • Views 4.2k
Anyone help?
Reinstall Chrome? Might work.
jts not just chrome, no browser will open. i click on the tab, the egg timer comes on for 5 secs then it just gos off and nothin happens
will any other applications load? and what version of windows is this?
Rest of comp is working fine. Done a scan with no problems, used an avg tune up and all is clear. It's xp
can you connect to the internet? From a command prompt, what happens if you ping say news.bbc.co.uk, does it resolved and get a response?
Im not great with comps, what do ya mean by ping? It says its connected and strength is good, just when ya click on the browser icon nothin happens
Ah just googled it, ill try that tomorrow when I get home from work. Thank god for my android phone lol
This could be a few things.
Try the command prompt thing above:
Start > programs > Accessories > command prompt
type
ping bbc.co.uk
(thats "ping" space "bbc.co.uk")
You should see 4 lines with reply from , bytes, time, ttl
sent = 4 received = 4 lost = 0
if all is well
If this connects then your internet connection is good.
Then try safe mode:
Reboot and keep pressing F8 until you see a menu
use the arrow keys to choose safe mode with networking
wait, wait some more and you should get an odd looking desktop - Don't worry all is fine
Try again to connect to the internet using IE.
Depending on the results of these two we can advise what to try next.
Good luck
Edited by Web Ferret
It might be that the desktop shortcuts have been lost.
Try going to "C:\Program Files\Internet Explorer" and click on the 'iexplore.exe' (or whatever browser you have installed)
Just a thought.
Cheers for them replies, I'll try them today and get back to ya
Right,the ping came back ok. Started in safe mode but internet will still not connect? Next step please web ferret?
Sent ya some pm's web ferret
Wait, don't force it - I'll get my hammer
Pms responded to suggesting a flush DNS.
If that still doesn't work try this:
1. Go to the command prompt again
2. Type netsh winsock reset at the command prompt, and then press ENTER.
Note If the command is typed incorrectly, you will receive an error message. Type the command again. When the command is completed successfully, a confirmation appears, followed by a new command prompt. Then, go to step 3.
3. Type exit, and then press ENTER. You should be prompted to reboot, if not you should reboot and test.
Reet ill try that in a moment and get back to ya
Have you checked the proxy settings?
On IE8 it's under tools->internet options, connections tab, LAN settings button - uncheck all the boxes.
Just Tried it, with no joy. Disabled all add ons too.
Is this a wireless or a wired connection?
If you are using wireless try using a lan cable and re-boot to see if that fixes it.
Another thing to try is to turn off your AVG firewall.
Ok ill get onto that as soon as I get in. It's wireless. I thought if it was connecting though then it was nothin to do with the router? I have been using my phone on the same wi fi network.
Wireless is a dark art sometimes.
I had a vista laptop with a similar problem. It always connected with the cable then the wireless miraculously fixed itself. Its a known bug with vista and wireless. I now have windows 7 on the same laptop and never have the wireless problem.
If the cable doesn't fix it then its a repair using the XP installation CD unless anyone else has any ideas.
Not had chance to try it yet, I have got the original start up disc I got with the lap top. Shall I use this?
NO
Do the cable thing first.
The XP repair isn't straightforward. Get it wrong and you will lose everything. The XP repair is a last resort.
RIght here is where I'm at. Nothin is working, there is no system re store points or Anythin. Gona. Try and remote chrome but its not in my add remove section? There is a load of other stuff in there though, could any of that be gettin in the way of somethin? By the way web ferret I greatly appriciate your help
have you got any kind of firewall or antivirus software installed? if so turn it all of for the time being and try and connect with IE again
