Blackvue Drive Recorders - NOW CLOSED!
hmm turned the sensitivity right down. And the car stopped recording when I parked it up at 0544 this morning. Then for no reason that I could see recording kicked off at 1821 tonight (while I was 400 miles away), it then merrily recorded the car park wall for the next 90 minutes until I got back and drove home. Curiouser and curiouser
  • Replies 135
  • Views 19k
Guys,
I've just noticed there is a firmware update (1.037). I've just done it via the android app. first time I've used it and its great.
I've just ordered a 32gb class 10 too, I want to keep it recording in 30fps.
John
Yeah did the update the other day
Sent from my motorola xoom using tapatalk
Hmmm, I must get the android app. How does it link up to the blackvue? Or is it just something to get on the laptop?
You need to put the micro sd in your phone. A but inconvenient but it's good when it's on. When I put my normal card back in it had a fit. This could be because it's rooted and the ROM and apps instal from the sd.
It was £195 delivered for the 400 (HD) model with 16GB memory card and mount. A bit less for the non HD version.
I got one in the GB - we'll have to meet up sometime if you want a look at it.
And yes, it's been a while. You available for the NW meet next month? (Sunday 4th)
Here's some footage from mine - set on Full HD and 15fps
Taxi stopped in a Keep Clear area - and then running a red light when he does move off
How to set the correct time on the 400? Mine is showing the wrong date and time on recordings.
Mine was wrong initially, but when I had the chip in my laptop SD reader, and accessed the Blackvue program settings, there was an option to change the timezone and then everything seemed to work out. Not tested on the road yet though sadly. It seemed to pull the correct date from the PC itself - like it read the date & time in the taskbar :D
I have set the time zone to London but the date is still showing as Dec 2010 and the time is also wrong.
I'm sure mine just sync'd. The initial recordings did have the wrong date & time but that was before actually installing. The second time it must have done it.
