Anyone bought any HID kits for under £50? I'm looking for some
I will probably buy a kit for £50/60.00 however on ebay there seems to be a lot for £39.00 etc.. Does anyone know if they are any good? they seem to be top rated sellers
Oli
Check out the ones on rclick website. Reputable company and well priced.
Thanks, what's the d2s slim hid which is £49, then there's slim hid for £44
Slims have smaller ballasts do can fit in smaller locations. Id recommend a slim kit over standard.
D2S is merely a bulb type. The type found in OEM xenons.
If youre inconciderate and like blinding other road users then definately worth it =P
Remember that for this reason they are not for road use and will fail an MOT. (just so you have all the information)
Thanks, I will be fitting Hids to normal headlights, then when I can afford projectors, I will be using the Hids in projector lamps.. which ones should I be buying?
Thanks for the help,
Oli
Oli
Which HID kit? H7 slim kit. In 6000k IMO.
Yeah, I have h7 normal bulbs at the mo? So do the hids h7 just plug into where the bulbs plug onto the wire?
Yeh, with the inclusion of the ballasts. It's all plug and play. You'll just have to drill a hole in the back of the headlight casing for the wires and grommet, secure the ballasts and upgrade the fuses. They'll come with instructions.
I don't mind blinding other people as long as I can see.
And they'll pass fine where I get my MOT done. (just so YOU have all the information)
Pretty much exactly what I said mate, it's fine if you're inconciderate and they should fail an MOT - if you get your car inspected somewhere that will pass HIDS without beam control, washers and levellers I'm sure they won't appreciate you broadcasting it on a public forum.
I just hope for your sake that if your dangerous lights do cause someone to have an accident due to not being able to see anything it doesn't have a family in it. Your choice if you wanna be that guy - at least you're willing to publicly announce you don't care ;)
Wow.
Just as long as those blinded people don't crash into you instead 'ey?
Still, look out for number one and screw the rest of the world - explains a lot about the behaviour you see daily in every aspect of life. emoticon-0101-sadsmile.gif
Will the HID direct ones set off the Warning lamp, It says on their ebay page they wont. But I know my luck Ill get them and they will.
Im going to fit mine in my normal headlights and wait till I can find a good pair of projectors.
Tim have you got any HID's off Rightclick website?
I bought my bulbs from there. Recommended from a mate who's used their HID kits for years
With projectors becoming readily available in the new year via the group buy wouldnt it be worth just waiting till then?
You don't need levellers or washers, and please don't post the 2006 article, check the general maintenance section and you'll see a link in the first post under HIDs page 28 of the document.
My HIDs were standard fit but didn't have washers or leveller do that proves that they pass the MOT no probs!
Edited by mdon
4300k is what I'd go for. Closer to OEM colour or at least it used to be.
B)
Mdon, thanks for settling the debate on washers and levellers, I can be rest assured now ;) I have bought some hids now with 6000k :) The help from members has been very useful, so thanks everyone.
Oli
