Octavia vRS Drivers seat wobbly
Only me!! Another question the drivers seat is wobbly, now this was only out last week and was all tightened correctly and been checked again.It just slightly moves side to side when braking or accelerating. I have had a look around again in previous posts and it would seam to point at the height adjuster unit in the Octavia. Just want to check as most of the previous threads where in relation to the Fabia.
Does anyone know the cost of the height adjuster if it is that? Please let me know its only one of them little things but very annoying. :doh:
Anyone? :'(
Anyone? :'(
Really I am the only person that has experienced this? Somebody must know??????????? :yes:
Hey Nutter, just try checking the bolts, you may well find a couple are loose? Just tighten them up and your away. G/teed to work mate.. :)
my drivers seat moves I've just not had chance to look in to it
Check the roller on the rail I had a MK1 and the bolt going through it ended up bending causing the seat to creek and move.
On the seat's height adjustening system is a bush wich gets worn,and the seat wobbles,you can't do anything aboy it :'( ,maybe a new seat. Mine does too,but not much.
Edited by IulianE
