Back seats in Roomster won't slide
Really loving our Roomster Scout 1.9 TDI, but have come across a problem with the back seats: they won't slide forward (or back) and seemed jammed in position, although they fold down ok and can be removed. Has anyone come across this? Many thanks
Mine can be tight sometimes. It helps to collapse the back onto the seat and then while holding the metal bar up at the front. Put one hand in the front middle of the seat with fingers wrapped under holding the bar up. Then with your other hand push the rear back and forward.
Remember it's just the outer two seats that slide as the middle one is fixed.....and just folds/removes..... B)
Yeah, never thought of that. And with the middle removed the outer two rear seat can even slide towards each other a little.
Correct!
