Help - 1st time Fabia owner
Hi all
Just got a 2001 Fabia 1.9 SDI - been a volvo driver before but seems like a good little runaround.
I have noticed it is quite boucey and squeaky - anyone have any ideas what problems might this point to?
The other thig that seems wird to me is the fan. It works on all 4 speeds (not much oomph though) but if the fan is on when it goes into reverse, the fan goes into a sort of 'boost' mode then goes back to normal when out of reverse ??
Last question is engine oil - the car had covered 134,000 - what oil should I be using, does good quality 10/40 meet the VW 500.00 spec?
Many thanks if anyone can help me on any of these matters.
Regards
ftocharlie
Hi and welcome aboard.
Hello ftocharlie and welcome along :thumbup:
Quick answer to the fan question is that it'll go into recirc mode when you engage reverse so as you don't drag in exhaust gases.
Your other questions will be best asked in the Fabia forum :)
