How To: Front Bumper Mod (wide mouth)
Bowders1
Recommended Posts
DIY FMIC Bumper Mod Part 1 - Removing Bumper
This is a mod i did some time back but just fix the links to the pics so reposted it. emoticon-0148-yes.gif
Car on axle stands ready to go
Remove the 6 torx screws on either side of the Bumper arches
Remove 3 torxs screws on the top of bumper
Remove the bumper grills to expose 2 torxs screws and remove them
Some VRS's have 2 screws underneath also remove these.
Remove the Bumper side bolts(10mm) 2 per side.
Get a helping hand to support each side and pull bumper forward and away from the car. Job done
This will expose the crash bar and the FMIC if you have one already fitted
I modded my Crash bar to expose more of the FMIC. That was my choice
Next part will cover the Bumper modding to expose the full FMIC.
  • Like 1
Link to comment
Share on other sites
DIY FMIC Bumper Mod Part 2
Ok this covers the remaing part of the modification to the bumper and final fitting. I can actually say I am very pleased with end result. It took longer to do it than probably most people would but this was due to me cleaning and re painting any part in site that I could not get to with bumper and crash bar fitted. Hope you like the result.
With Bumper removed mark up the area where you will be cutting. This will be the reg plate area and the sides and bottom of the bumper to remove the remants of where the reg plate was and the centre grill fitments. I used a jig saw to first roughly cut out the area.
Then used a rasp to get closer to the marker lines
Then finnally used sharp knife to gradually work the the line and finnish off with sand paper to make a good edge for the mesh to fit up to.
View from back
View from front. Note I left slight lip at the top to allow the black trim to fit into the oem holes and the mesh to overlap the top(can't see this when trim fitted)
Use cardboard template for mesh, marking it out through bumper opening (you could just offer mesh up to the bumper opening and mark it, but i found it awkward so preferred this method)
I then sat template over mesh and marked mesh with masking tape. I then left an extra approx 10 to 15mm(shorter at the top of the mesh) to allow for folding it around the rear of the bumper lip. I cut it and offered it up to the rear of the bumper and then trimmed back any access.
Then I offered up the mesh and taped it in place to hold it. I then carefully folded back the extra part of the mesh around the bumper lip and pressed it in place.
Pic of mesh sealed in place (tiger seal) left over night with some heavy object pressing down on the sealed areas to keep it tight against the bumper lip.
Finnshed Mesh in place. Note the top of the mesh sits over the front of the bumper. This will be sandwiched between the black trim and bumper to give it extra support.
Refit bumper (side grills not yet fitted)
Closer shot with side grills(milotec) now fitted. I got a nice match with the honeycomb grill effect as the milotec ones.
Pic of the finnish to the bumper with mesh sitting nicely. Paid off using some weight to press the mesh to the bumper overnight.
Front end shot
Showing the lowered stance of the weitecs
Pic of the reg plate cut down to size. Left around 5mm around the lettering
Could not resist a shot of the engine bay showing shiney bits and FMIC top
Thats it folks, hope you like it.
  • Like 1
Link to comment
where did you get the side grills from mate? i so wanna do this mod to mine now i seen it!
Yep Milotec ones
can get them for here:
http://www.superskoda.com/octavia-i/sportgrills/skoda-octavia-00-07-rs-facelift-3pc-grill-v2-for-oem-bumper-milotec
that is where I got mine. :thumbup:
Link to comment
Where did you get a big enough bit of mesh from to fit the cut out because i carn't find anywhere that sells mesh sheets big enough
Will try and dig out the original pack that I kept the leftovers in the shed and let you l know.
It was purchased on ebay though.
Link to comment
In the second post about pic 14 or 15, why have you got a number plate on top of another number plate? Is that so you can do over filling stations and not be traced? Lol :)
Link to comment
Dam been rumbled...... :giggle:
Actually that is only one plate. The angle and light reflecting on it looks light 2 plates but you can see the black lettering running through the plastic edge.
That's my excuse and i am sticking to it...
Link to comment
strange question.
Does the insurance company class this as a modification for insurance purposes as it is technically an original bumper? :think:
IMO , yes. Think if you had a knock and the insurance company had to pay for the repair to the bumper. If you declared it, no questions, you'd probably get a new bumper / crash bar reverting you to standard look at worst. At best the labour to modify the new bumper would be included in the work the repairer carried out. If you didn't declare it, they could say it made the car more attractive for theft / infringed the safety of the car (ie cutting the crash bar) so giving them a good excuse to repudiate a claim. Best to ask them , pre-mod and prob won't make alot of difference to your premium.
I asked a similar question when I put the vRS bumper on my 4x4 and cut some of the back out to clear the FMIC pipe.
Edited by modra_vrs
Link to comment
that's what i was thinking, just was looking for other peoples thoughts.
Cheers :thumbup:
Link to comment
i told my insurance company i have done mine and they are fine with it. replaced the center part of the bumper with mesh to allow for a bigger better intercooler.
they didnt charge me any more for my remap either. Happy days
Link to comment
i will also be interested in where you got the mesh for the big mouth...  i cant find none other than halfrauds stuff that is to small
I got mine on ebay from a company called Direct Automotive
size was 100 x 30 cm
but found this on ebay which is perfect
http://www.ebay.co.uk/itm/ALUMINIUM-BLACK-MESH-GRILL-KAMEI-HONEYCOMB-A2-A3-A4-A5-40X100cm-/140653665091?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20bf9c9b43
good size holes
or this one
http://www.ebay.co.uk/itm/ALUMINIUM-BLACK-MESH-KAMEI-GRILL-SUBARU-TOYOTA-30x100-/120745491571?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c1cfdfc73
Link to comment
  • 3 months later...
  • 4 weeks later...
Great guide mate,
Will be doing this when i get round to the FMIC.
Is there any chance you can sort the links out in your N249 removal thread mate?
I have tried many times buddy to get deleted pics from PC and not getting much luck, will try again soon but may bite bullet and re create some when i get time.,
Link to comment
  • 1 year later...
  • 4 weeks later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
