Leaks leaks leaks an more leaks
A couple of months a go I had a leak in the passenger foot well and I fixed it but now I have another leak it's coming from around the fan housing behind the glove box. and when I opened the flap behind water gushed out:(
The cars going to the garage tomorrow but does anyone have an idea on where it's leaking from???
Cheers mike
Bet your scuttle panel is full of leaves blocking the drain holes.
Scuttle panel runs directly into the cabin filter hole :) check it isn't clogged up with leaves etc...
Something like that anyway haha, only what I remember reading on here.
Snap :D
Silly question what and where is a scuttle pannel
Recently removed off side wheelarch liner and before refitting noticed 2 inch long hole at end of scuttle FULL of leaves, scooped them out as a precaution to problem of water ingress.
Scuttle panel is just below windscreen
Cheers guys will give this a try
Wow it was full of water. Thanks guys for your help.
