High timing pull? Why? 3rd gear log attached
Ive just done some logs on my mates mk1 VRS, From what I can see boost and MAF look ok. TIming looks high though? What can cause this? Ive read anything over 6 is bad? Car is 100% standard. Ive attached logs of 115,020,003 and also 118,031,003. Can anyone shed any light on the issue? He has had a problem with revs not dropping when changing gear thats why we did some logs.
LOG-01-003-020-115.CSV
LOG-01-118-031-003.CSV
Sounds like pre-ignition is occuring if it's running on at high revs when it should be dropping (between gear changes). That would explain why the timing is being pulled as well, to try and minimise the pre-ignition.
I can't open the logs at the mo and am just off on holiday for a week but things I would suggest cause pre-ignition are too hot spark plugs and intake temps too high, possibly engine running too hot as well.
sounds like a case of water meth required:>
what fuel you running as that looks like a lower octane fuel
when did you change the fuel filter??
He had just filled up with std shell fuel before we set off, Dont know about fuel filter? Maybe worth a try. Hes going to get some new plugs tomorrow see if that helps
i would advise you run a tank of super and change the fuel filter and run the check again
whats water meth for mate ?
Water methanol ;-) used to cool intake tempa and run more ignition advance when tuning ;-)
Basically like running race fuel
cheers pal....
i always run mine on Super, car is so under powered without it.
the car goes in skoda on tuesday to get new coilpacks as the car was recall for the coils....am going to put new plugs in and fill the tank with v power and ask my mate to do another run for logs.....thanks guys
whats the best plugs for mine that i can get from eks? or pat number,,thanks
coilpacks done,next plugs
Just use oem plugs ;-). Fancy plugs cost lots and do nowt
am getting some ngk brk7e
i cant find the plugs that i wanted that are brk7e do you know where sells them
local tps standard plugs are perfect just ensure before you fit any new plug is you gap them properly you will be amazed how often this isnt done and then causes issues
changed plugs and still the same........come on people?
Have you changed the fuel filter ??
am doing that to morrow....
could a lamda sensor be the prob?
clutch sensor was missing and the over reving has stopped when fitted the sensor..still getting timing pull at 8
can you do a new log showing the same again please
il asked me mate to put it on..thanks
Here is 3rd gear log, Looks like it has pull on 3 cylinders? #1 looks ok?
LOG-01-020-xxx-xxx.CSV
