octavia mrk 1 vrs oem dv failure ?
hi guys,,just wondering what are the signs of symptoms of a failed oem dv on a 03 vrs octavia. ? and is there a ay to test them to see are they working properly ?
cheers
if the DV fails it's inner membrane goes rubbish. the way to test it ? unplug the top DV hose and verify it holds pressure or vacuum (the valve). if not it's done.
