Pic of oil filter in Engine bay -Can anyone please help?
Hi Guys,
need to get this done at home. For the life of me i cannot remember where the oil filter is!!!!!!!!!!!
I've taken the engine cover off, but still my mind is blank!
Can anyone here upload a photo???
Don
Big round thing in front of the engine with a 36 or 32mm nut as part of the plastic cover :)
This pic shows it quite clearly
Hmm that oil filter cap looks odd, mine has grooves round it so you can undo it with a chain wrench, much easier than trying to undo it with the plastic top bolt that can chewed up easy.
If you use the correct socket there is no problem at all, mostly because it's not done up that tight.
