Splined tool for vRS hub strut removal
Another Tool question! This time the splined bit needed fro the hub nut.
I believe it's M14, can anyone confirm this?
Also, has anyone used the 'bit' or should i splash out on the 'socket?
Bit: http://www.ebay.co.uk/itm/M14-SPLINE-BIT-12-Point-Socket-10mm-Hex-Drive-30mm-long-/110656623985?pt=UK_Hand_Tools_Equipment&hash=item19c3a61571#ht_500wt_922
Socket: http://www.ebay.co.uk/itm/M14-Spline-Bit-1-2-D-100mm-Long-Laser-4147-/190598599459?pt=LH_DefaultDomain_3&hash=item2c608fd323#ht_2898wt_1163
Opinions on the tools would be great,
Thanks,
Mike
if you have a beefy 1/2"drive 10mm socket go for the cheeper one but I wouldn't use it with a 3/8" or 1/4" drive 10mm
I've got 1/2" drive so i'll give it a go! Cheers for the reply. :)
Ah, you got me guessing there - I thought you meant the large bihex socket for the drive shaft, now I see that you mean the "TORX" headed bolt that clamps the hub on to the strut, yes its M14 SPLINE - I'd buy the Laser one - I think its a Sealey one that I bought as that was what I found first.
I brought the socket one off ebay a little while ago, works perfect mate..
