Headlight supplier
Hi Briskodanauts, I'm considering replacing the headlight units on my Fabia. After time the lenses have dulled. I tried buffing them with varying degrees of success but I'm not happy with the results hence the replacement. I just wondered if anyone out there had used ultimate lighting on fleabay http://www.ebay.co.u...=item43a7e8c468 Did you find the parts you ordered satisfactory? I see they have 99.8% positive feedback but thought it was worth double checking on here. I think £42.95 per unit's a great price if, as they, say they are OEM and manufactured by Skoda. Thanks in advance, Lee.
anyone :think:
I got a replacement front indicator unit for the wife's Almera from them last year. It was reasonably priced cheap to post and arrived in no time (to ROI) I would have no hesitation using them again and have recommended them to others. No problem with quality of the part either.
I bought one from the same guy, had no problem fitting it and looks identical :)
cheers buddy, going to go ahead and order.
No worries man :)
The ebay advert doesn't say what make the headlight is. I bought a replacement headlight as a pheasant smashed it, it was made by Depo.
I wasn't at all happy with the quality of the Depo unit. Everything was stiff and the wire clip did not hold dipped beam bulb very well, it was very loose. However with a bit of bending of the wire I made it fit. I'm sure the beam patten isn't as good as OEM. On the plus side it was about £25 cheaper than the OEM Hella unit.
