blue samco egr to intercooler boost pipe for fabia vrs
hi guys hope you can see the pic let me know if you cant cheers matt
Hi Greening. I'm new to the forum, and trying to find out some information about the aluminium connectors on the pipe you posted a picture of.
Could you tell me if the aluminium connectors at either end of the pipe are the same component (i.e. the EGR valve connector, and intercooler connector are the same)?
Any help would be most appreciated!
No the alloy ends are diff sizes the egr end is bigger than the intercooler end
i have a few blue samco pipes, its the one that go's from egr to intercooler, the pipes are a direct fit,they come with alloy mounts at each end so just pust in and job done, they are all brand new i have 5 in total they look the bomb when fitted
£80 each plus postage or pic up,, if any one wants pics just pm me
Do you have any of these pipes left? I've just noticed my pipe keeps blowing off at the EGR valve! I cant seem to find any OEM parts for sale anywhere. I've done a DIY EGR delete with golf tee's so if none are available I might go down the "EGR delete kit" route and fit some Samco elbows and jubilee clip onto the delete kit. Any pointers on the pipe sizes?
Sorry mate no samco left but i do have a standard set up if your interested??
What do you mean by standard set up? Are you talking about the original tubes? I ony require the one that attaches to the EGR valve.
Here's a pic of mine fitted. FAT!!!! B)
Worth noting mine is welded to my Allard EGR delete so not exactly the same as the ones Matt is selling in terms of fitting although supplied by Matt with OEM alloy fitments :thumbup:
Did you fit the hose onto the OEM fitting for the intercooler? I like the look of the EGR delete.
Yes the standard 90 bend from egr to the plastic pipe
Hi Greening do you have the Samco part number for this hose?
Did you ever find out the Samco part number?
Edited by west_244
No. Fitted the boost hose, EGR delete, BFOFMIC, clutch, turbo and fresh software all the same time.
But it would couple up to an OEM intercooler :thumbup:
Can you still get these
