Dash Squeak
Hi All
I have a very loud squeak coming from the dash at the moment. Like a fast rubbing sound when the car is moving. I think I have narrowed this down to the corner on the passengers side. Is this common? Im guessing it will go away after a while as im hoping it's weather/age related. Car only done 5k.
We've got something like that. By coincidence, our 2010 Scout is with the dealer today, having a look at that and a couple of other potential warranty issues.
If they manage to resolve it, I'll let you know.
Does it stop if the blower is turned off? I've got a squeek and I know the blower motor is in that area causing it.
I've got a squeak coming from the passenger side dash to. If you press near the trim going across front it stops. It's pretty loud too. There is a thread on here somewhere about dash squeaks. I think it mentioned the trim on the end by the door rubbing on the door seal. Mines a 59 plate and full of rattles. My 53 plate Mk 1 I had from new never squeaked like thus.
Nope continues with the blower switched off. It's quite loud and annoying.
+1 - Mine also squeaks in the same area, but normally only when it is hot. I think mine is caused by the dash rubbing against the passenger trim near the windscreen. I have pushed a piece of rubber between the two and will see if that stops it. Others have reported the glovebox lid squeaks when closed, but they all seem to be at the passenger side.
It drives me nuts and that in turn drives SWMBO nuts when I ask her to push the dash to try and stop it. Her solution "turn the radio volume up".
Thinking of a new Rapid when they come on the market, so then it will be goodbye squeak.
Perhaps only to be replaced with another squeak or squeaks
"Perhaps only to be replaced with another squeak or squeaks"
I have had numerous cars of different makes and all have some squeaks, rattles etc but the Octy has been the best for not having too many issues. If I had to show SWMBO your post the Rapid or any other new car would be definitely out of the question.
I have a squeak on my passenger side. I eventually got rid of it by telling her to get out! :rofl: Boom Boom....
If you remove the cover at the end of the dash trim that is visible with the door open, inside you will see a torx screw.
This seems to be what most people attribute the squeak to.
I have it on mine and loosening the screw might remove the squeak. At some point I'll put some fibre washers in to see if that stops it completely.
HTH.
Apparently they've managed to reduce it by "about 80%", (how they measured that, I'm not quite sure), just by tightening some fasteners, but they're going to replace the glove box catch which they think should eliminate it completely.
Know it sounds strange but try moving the Arm Rest forward one notch. I had a squeak in my VRS and was sure it came from the passenger side but ended up the cause was the arm rest. It only occurs when the arm rest is pushed right to the back.
Tried arm rest and glove box. Squeak is definitely coming from the passenger side dash/door and it stops when I push the dash down. Will try the the screws as suggested above.
I hasutherland very same squeak develop when my vrs was 6 months old. Took it back to my local dealer who sorted it by inserting padding to the front near side dashboard. A year later, the car remains squeak free. Sorted cost free under warranty.
Edited by kevberlin
Sounds good. Any chance of some pictures to see what they have done?
Afraid not. They removed all the dashboard and padded out underneath the front near side corner.
Found this for the area concerned.LHD model shown
That is the area where the padding was inserted. A picture saves a 1000 words. Good luck.
Which dealer was this?
Savilles Skoda based at Mustow Green near Kidderminster in Worcestershire.
Mine was fixed by the technician who removed the A pillar cover and taped up the cables inside. Not squeaked since in 40000 miles.
Gone into Winchester today so will see what they say.
I managed to narrow down the squeak to the dash by the corner by the windscreen on the passengers side. When I put pressure down on the dash the squeak stopped.
All fixed. They found some loose paneling behind the dash which has now been padded and secured. All done on Warranty. Thanks Winchester Motor Company
This is where ours squeaked, well.... it was inbetween the air-vent surrounding & the lower section of the dash
I shoved a wedge of gaffer-tape in, & pushed it out of sight with a screwdriver.
No more annoying squeaks
