VERY high spec octavia 4x4 turbo estate for sale 235bhp
Professionally modified Silver 2001 Skoda Octavia 4x4 turbo
Due to company car allocation I no longer require this fantastic car. I have very recently had the full engine / box out and replaced the clutch solid flywheel and vr6 clutch / cover. The box has the longer VRS ratios compared to the normal low ones on the 4x4 setup. This gives a lot better cruising capability and also easy 35mpg on a mixed run compared to more like 30 at best in the original ratios (40mpg on a steady motorway trip easy to obtain). During the engine out I transplanted a load of upgrades and cleaned / tested or replaced all most every single item
Running the latest revo stge 2+ software is pushing about 235bhp and utilizing the k03s turbo gives instant response and more than enough to surprise other sports models mix this with fantastic traction of the 4wd is a real performance sleeper and great in bad weather making it a very safe, practical performance car
Full 12 months tax and 12 months MOT and full service completed 2k ago, always ran on v-power
Servicing
FULL service history with regular haldex oil changes also, last 2 services completed by myself with oe or higher spec parts
Modifcations
Revo stage 2+ remap on K03S standard turbo
Carbonio Cold Air Intake – carbon intake pipe and cone filter located down behind the front bumper
Forge Front Mounted Intercooler including properly modified bumper bar, Neuspeed large diameter metal turbo intake and Intercooler pipes. Headlamp wash still working
APR R1 dump valve (recirculates correctly), relocated to the front.
Blueflame full exhaust with single sport cat giving a sportier sound but not particularly loud, tweaked exhaust to retain oe 4x4 exit to keeping the tailpipe out of sight
Secondary air pump removed and correct removal of all surplus vac hoses etc
New exhaust gasket
Spark plugs changed 10k ago
Cambelt and water pump (oe parts) fitted 10k ago approx 1 year
Steering fluid changed 2k ago
Oil and all filters changed 2k ago (oil, pollen, fuel)
New oe fuel pump fitted in oe housing 1k ago < >Octavia diesel engine sound deadening under bonnet
Transmission
Rebuilt gearbox in 2008 by Awesome at a cost of £1200 fitting internal gearing higher VRS geared and lower engine RPM for cruising. / economy.
Clutch / cover new oe items fitted 2k ago
New G60 flywheel, no DMF to worry about
Neuspeed shortshift kit – smoother short throw shift < >Last service had new oe gearbox oil and dot 4 racing fluid approx 2k agoFronts - new
Brakes
VRS spec 312mm discs and pads front (oe discs and tt pagid spec pads). Carriers were upgraded to allow increase in disc size from the standard 288mmNew rear discs / pads November 2011 oe parts. Racing dot 4 fluid just changed 2k agoNeuspeed front 25mm ARB and poly bushes.
Suspension / Chassis
Neuspeed front upper and lower strut braces (upper not fitted)
Poly dogbone engine mount.
Koni HA Coilovers, Height adjustable but set at the highest setting retaining good ride comfort and ground clearance but superior handling control.
Neuspeed on-car adjustable rear track control arms. The 4x4, unlike the VRS has fully independent rear suspension, but not adjustable on-car from standard and required to keep the camber in tolerance.
Neuspeed rear 22 mm ARB and poly bushes.
Suspension setup to TT Spec done completed July 2012.
New steering rack ends (oe oe audi tt ones) 2k ago
New power steering pipe fitted 2k ago due to slight leak of original
New lower ball joints (oe audi tt ones) 2k ago < >Full tow bar and electrics fittedVRS front bumper and silver grill surround < >Audi TT 7x16 alloys with 205/55/16 Avon ZV5’s all round, 3-4mm tread – I have a full set of Khumo KU31 approx 5k old also available which I could fit dependent on sale price
Interior
2004 Leon Cupra seats. This suits the car better as they maintain the 4x4 side airbags wiring. You don’t get side airbags on the VRS. This gives you an extra NCAP star over the octavia vrs
vRS Leather 3 spoke steering wheel
The car has all the standard 4x4 goodies as it’s based on the Elegance specification:
Climate Control (nice and cold) re-gassed last year
4 x Electric Windows / Remote locking.
Electric Tilt Slide sunroof ( very rare on a vRS)
Golf Mk4 sunglasses holders (useful mod for his n her glasses) – not fitted and handles still in place but happy to fit if wanted
OE skoda interior rubber boot mat
OE skoda metal dog guard (also for safe storage)
OE genuine floor mats front and back < >VRS interior trim on facia / gear surround
Car has completed 122k which will increase as still using this month, not only is a fantastic family car but very practical and tows very well. I have towed my track car multiple times and does this without any issues. The car ran stock 150bhp for the 1st 112k with full dealer service history. Engine pulls strong with no faults or issues at all. There are a few minor things to point out that I have not got round to finishing yet and now due to selling am not going to bother tbh. Rear tailgate has the common start of some small rust patches (highlighted in picture), keys need synchronizing to allow button lock / unlock (kar locks by using drivers or boot barrel lock), few very small faint scratches and minor stone chips out of bumper it is an 11 year old car still and overall in very very good condition.
The car is in use and available to view until 21st August and will be off the road after and unable to test drive due to insurance and will be stored in the garage. Those in the know will confirm this car is built on the mk4 R32 platform and shares the same Quattro setup and all the know upgrades to the chassis have been completed with subframe strengthening and other supporting mods. Turbo had no play or cracks etc when the engine was out
To have purchased all the items new on the car and fit you are looking at a very large number in deed (approx £12k has been spent on the modifications fitted to this car from the last few years with paper work to support)
I am happy to answer any questions and the car really has wanted for nothing since my ownership and spent far more on it than the asking price, let alone the labour costs it would be to pay someone to fit these parts. Never let me down and been effectively audi parts I am sure will do another 100k miles with correct servicing. Skoda de spec'd this car to not compete with the higher audi items on sale and I have effectively turned it into a well spec's audi S3 estate
I have a haldex blue controller that I have not fitted yet and would include this in the sale for £500 extra. It engages 4wd on acceleration rather than the stock 4wd on slip angle of the fronts and a great bit of kit – was over £700 new
- non smoking, in fact no signs of anyone smoking in the car from the ashtray
- No oil leaks, boost leaks, fuel leaks - can provide more pictures on request
On ebay atm but would much rather sell to a member her to enjoy and appriciate the hard work, costs and time put into this car
http://www.ebay.co.u...984.m1555.l2649
£3000ono and happy to work a deal on top of the blue haldex / nearly new tyres / roof bars etc etc
bump
a really nice example, I love properly modded mark I 4x4's........ GLWS
Thx,
Can't believe no genuine interest yet. Epic car and massive bargain for someone
DG
I've been staring at that on eBay for a few days. Wish I had the cash. Good luck.
You couldnt get 3mpg out of that vlad - without changing ways, and ignoring hot hatches. Seriously nice motor though this.
That is true... but I wouldn't buy something like this to drive slow! :giggle: I'll see what direction my career change takes me...
Prov sold to a well know member ;-)
Clive?
Clive?
U thought the exact same when I saw the advert :)
As confirmed Clive is going to take the estate forward and use it as I wanted. Really nice guy and happy its going to a good home, got a bloody great deal also lol
DG
Are we starting a new game
HOW LONG TILL CLIVE BREAKS IT? :giggle: :giggle: :rofl:
I'll start 9th September.
Sorry Clive couldn't resist ;)
Lol this is a keeper ;-) i can assure you but it will go through a few changes ;-)
Clive, you should bring this on the Brisky How Fast day, 1st September. Would be a blast. :)
i might do buddy need someone to show me how to drive though lol
now where is kev !!!
Come on Clive, no point building monsters of cars if you don't get out in them. ;)
I'm sure you can sort out an experienced co driver if you are a bit inexperienced.
If in doubt....flat out :)
lol
if i can get the day off work i will come along and test the haldex out ;-)
this one wont be a monster !! just a 200bhp family car
the other one will be something a bit different lol but wont be ready in time but as soon as its done im sure the new owner will be driving it HARD
Brings back memory's
I still miss my 4x4
SOLD to Clive, very nice guy and happy its gone to the right buyer
DG
Thanks máte just got back and unloaded
Top guy thanks the start of a friendship ;-)
