Swapping a stream with a bolero?
As above, are they exactly the same size? I've got a 56 plate sport, with aircon and not climate.
Will I need a different surround/dash panel?
John
if you get the octavia version they are exactly the same size, however depending on the age of your car you may have to upgrade the can gateway as well to avoid a battery drain issue.
Bolero slots straight in, definately check the CAN gateway as you may need to swap that out to avoid battery drain. You will also need to program the new gateway unless you buy it pre-programmed.
Isn't the Bolero unit the same size as the Columbus, therefore needing the different surround?
Depends where the Bolero has been sourced from. Mine was a straight swap (Mine came from an Octavia). However if I had a Superb then I'd have needed a new fascia for the Bolero to accomodate.
I have a Bolero from an Octavia Im looking to sell, great nick complete with code!! Open to offers!! Would advertise it on here but am unable to complete the process to become a freedom member?!
