Uprated SMIC? Another IC option!
As in the build thread, Is it possible to avoid the silicon bend by welding an alloy bend onto the IC outlet?
  • Replies 129
  • Views 17.1k
  • Intercooler and pipe work mocked up ready to get fitted!
  • To be honest, looks like there's loads of room in the bottom picture, it's only thicker not wider or taller so should be ok? Thanks for the pictures as well, plenty of good ones!
  • Fine I'll do some logs Won't be on vcds as I sold my vagcom when I left the trade. I have a launch diagnostic computer so will use that. However.... Logs before might be difficult as the bottom boo
Not to weld more pipe on, but it would be possible to change the angle of the outlet. Would have to be a good alloy welder though.
Ah, so cut the existing outlet at an angle and weld new on. Was thinking that the right alloy pipe would be significantly slimmer than silicon plus clamps.
J.
Yeah basically, that's right.
I mean... It works, don't get me wrong, but having the top outlet at a different angle similar to the standard intercooler would have helped the fitting.
  • 2 years later...
BumpIng an old thread here, but I'm curious to see if any logs were made with the new side mount.
