How do I make my vrs whistle on gear change
Heard loads of fabias do this alot and to be fair it sounds really nice my mates bora does it to. I was told to take the cat out and I would get the desired result. I cut the cat out and welded a bit ov pipe in instead no change to sound so tried a stainless steel back box instead of standard one still no change not even when I tried it before I welded back box on and it was straight fru. Clearly I have done something wrong or I just have to pay for a proper system. Can anyone help me by telling me where I have gone wrong or if i have been just stupid.
Cheers stu
Are you referring to the whoosh noise like that made by a dump valve Stu?
Edited by SkodaFabiaOwner
Whistle like this?
Just blow every time you change gear.
Or if you wanted to be really trick you could play a tune :)
Very gud lol where can I get one of these from
Yes but sound comes from exhaust
. Yes but sound comes from exhaust
It's the Decat that allows the noise from the turbo to come through. I had a full milltek turbo back no res and that made a loud whistle / cooing sound. My mate had a pd100 cat and middle silencer removed and that too made the desired noise.
Edited by bondi
Whistle like this?
The guy is trying to ask a serious question here!
I think this is what you are after:
Insert this when changing gears:
Edited by JLneonhug
LOL
My mate made his car do this, but he's selling up now.
Cheers stu
Let me get this right you have done quite a bit of work plus spent quite a bit of cash to hear a whistle when you change gear I got to ask why.
In all seriousness though - it's the way you drive it. Mine does it will a mufflerectomy. I still haven't got it quite right but its not a noise that I was setting out for it to do.
I get a whistle from boost (possibly a tiny air leak), and flutter (AKA 'owl' / 'Pigeon' noise) when I lift off at low-ish revs.
I think the easiest way to achieve the flutter noise is to increase the bore of the exhaust. Or steal a pigeon and gaffa tape it to the roof.
I get the "whistle" noise between 2000 - 2500 revs when I accelerate...
...that will be all... :think:
You want Owls, enrol in Hogwarts. :)
Seriously, the Fabia's a well sound insulated modern car. Try doing tunnel runs after each mod to try to gauge the difference. Or a cutting or anything where there's a tall wall nearby. To be clearly audible with the windows up whilst driving will likely be quite loud.
Having the turbo quack is much better I reckon!
There's no point as dump valves don't work on diesels. (plenty of threads explaining why)
However, if you could, that would be hilarious. :rofl:
Pmsl at the duck noise!!!!! If someone fitted that they'd be unbeatable in a race as everyone else would be in stitches of laughter and unable to drive!!!!
Ooh interesting, will have to read about that!
Someone shoot me lol
take the silencer/back box of and replace with a straight pipe and well a tip on? if thats the sound your after? you'll get a owl sound wooshing out the tail pipe where the pressure is released
