headlight removal hid fitting
I didn't realise that the shutter option was gone on the 2012 cars. :)
wouldnt no mate as my audi/vw tec says his vagcom will not connect,it connects to everythink else on the car but not the central electronics moduel and thats were you need to be
  • Replies 152
  • Views 24.6k
  • Excuse me for a moment Buddy while I inhale your grief. How can I explain to you why your guy is unable to do anything? my man has a genuine Ross tech kit. I personally plugged it into my obd port
  • Absolutely no need for you to make this remark at all. If you'll notice the "illegal crew" have stayed out of every single discussion that has appeared here. Why? Because there is simply no telling so
  • That looks like the slimline ballast kit from eBay seller londoncolour to me. I take it that the person who cannot access the CECM on the latest cars is using a genuine VCDS cable and the latest vers
was also on the phone yesterday to mikeholroyd and he confirmed what my techie was saying,top and bottom of it is skodas dont like you changing bulbs to led or any other type and will 9 times out of 10 put warning lights on,iam also back to original bulbs now as dont want to do any damage
On my last VRs I changed the coming/leaving home lights to fogs. I am sure I saw the shutter option on my 2010VRs.
you mite have done on a 2010 but this is a 2012 and maybe they have changed it
All depends what version of vcds you are using
Edited by alberg
I also had my fogs as CH/LH lights
Also had fogs as cornering lights.
I am no expert but the CANBUS versions will load the system with capacitive loads and this is what COULD cause damage to your controllers. Some kits come with cables that fit between the supply and the HID controller (these are the capacitors).
I think the best (and it seems 2012 cars need firm confirmation) that NON CANBUS with coding is the safest.
biggest mistake ever listerning to this,bought none canbus ones and fitted them spot on in an hour,tried lights with car not running and these work fine,tried lights with car running and flash like hell,connect vag com and it wont connect to the lights,and to make things worse ive got a warning light on my dash,joke this brand new car now with no lights
Please point out what is incorrect in my post?
pre-FL = non canbus and coding
FL = possible problems and more than likely a canbus kit required
Don't rant when you buy the wrong kit and it doesn't work
Any more progress on a CanBus system working on a Blackline without p*ssing about?
Looking to collect my Blackline on Monday, have a set of canbus ballasts and cancelers,just in case,waiting to be fitted, be interested if any one else has finally fitted a set of hid's without any problems...
Let me know how you get on. If it works ill buy the same kit as you.
You'r post above contradicts what you are saying now.
I really and truly you hope are calling your own posts retarded and not insinuating anyone on here including myself are retarded? :x
I have been in contact with the guy that coded my last car for the HID kit along with other changes in the system.
He is a techie in the Skoda dealership I bought both cars from.
He will check the coding list over the weekend and let me know what the situation is on Monday.
Until then, I will sit and wait.
You do know there is a difference in the coding between Pre FL models and FL Models as far as I am aware.
gess your techie didnt get these to work
He had a very busy two days and did not get time to check it out, he said he will get it checked asap for me.
I can only sit and wait ;)
well it was confirmed again that theres no central electornics access on the new 12 plates
Hoggy, what does that mean in English?
in english it means you cannot code them in if needed to be,so for these to work it will have to be canbus ones
So now we need someone to try canbus ones in a blackline and hopefully we have a definitive answer.
Sack your Tec guy. :giggle:
Got my car coded today and fitted the NON canbus HID's as I did to my last vRS
Fitted hid Non canbuus 4300k kit
> Working with engine off and engine running
> Drove the car.
> Perfect
> No Warning lights in dash.
Also ticked box for LED Number plate bulbs. This turned off the warning light on the dash,
Also got Fogs as CH/LH
Also Fogs as cornering lamps
So as it stands,
Yes, you can fit non canbus HID kits to 2012 cars just as I suspected.
Lamps removed for fitting
Drivers light working
Both Lights working
Dash showing no errors
Ballast fitting position
not with vcds you cannot do this,explain what he has used cause ive tried this now on 3 cars all with no joy
This was done with vcds.
If you want to be anon believer based on the fact that your guy cannot di it then so be it.
But please do not give wrong advice to others and cause confusion as a result.
I have proven today this can be done.
Vectra, have you got a link for the kit you used?
I take it that the person who cannot access the CECM on the latest cars is using a genuine VCDS cable and the latest version of VCDS, as the last update did a firmware update to my cable.
This time I got the 4300k blulbs as I had the 5k in the last set but found them a little too blue for my liking. I just went for a short drive now and these are pure white compared to them and Certainly much better light from them.
http://www.ebay.co.u...=item4cec249814
This apparently is the trick though.
my Tec guy told me to do it in this order.
Code the car for the HID's
Do NOT,, I repeat.. do NOT turn on the lights.
Install your Hid's "BOTH" and when done it is now safe to turn them on.
Good advice - code before fitting.
