Hub torque
Hi,
Anyone know the torque setting for the hub not on a vrs? Can't seem to get it anywhere!
Just went through a new SKF bearing in under 4000 km's so wondering if I had it too tight or loose.
Thanks James
This is the instruction as printed in elsawin:-
If the wheel bearings are loaded through the vehicle's own weight, the wheel bearing will be initially damaged. This shortens the life of the wheel bearing.
– Depress brake pedal (assistance of second mechanic required).
– Tighten new twelve-point nut to 225 Nm and release by 1/2 a turn.
– Torque wheel hub a further min. 90°.
– Tighten twelve-point nut:
Tightening torque:
50 Nm + 60°
Hope it helps - I take it you mean front bearing?
That helps a lot, yes it's the front bearing!
Although I'm probably not far away I didn't use the tighten and release sequence!
