Whats the diffrences between VCDS lead and a ODB2 lead?
Im looking into buying a lead to do some changes in the VCDS for my new Skoda Fabia.
But i cant seem to find information on what the actual diffrences is between a cable from for example ross-tech and a regular noname ODB2 lead? I already have a ODB2 lead that ive used for my motorbike but would that do it if i bought the software from ross-tech?
Here in Sweden the basic VCDS lead and software costs about 400euro from the Swedish retailer.. So im hoping to escape a bit cheaper than that..
if you want to use VCDS then you need to buy the Ross-Tech cable, there is no other way since VCDS looks for the Ross-Tech cable and will not work without it. The OBD2 lead you have will plug into the car, but the software will not work and neither will VCDS.
<br />Ah okay.<br />But what are the differences between all the Ross-tech leads
Edited by Snowman89
Check the Ross Tech site they do a list of cables suitable to particular models, the Hex-Can cable seems the most popular.
An OBDII set up for a VAG car will only provide you with emissions related system failures. That is the only thing required by law under OBDII.
A VAG level tool will give full access to all modules whether or not the module has faults that emissions related.
Ross-Tech VCDS is full VAG. The factory tool costs thousands...
OBDII interfaces do not work with full VCDS - you must have a genuine VCDS interface to work because the license for the software is electronically encoded in the interface.
I believe the Fabia will work with our VCDS-Lite product. You need a KKL style interface that you can buy on eBay. Look for one that is compatible with VAG-COM 409 or VCDS-Lite. Then you should be good to go.
