help! sump cracked I think, anyone in Newcastle too?
Hi guys,
Pulled into a garage with a stupidly raised drain cover and heard a really loud bang!, thought the worse and drove 100 yards or so to see a small.puddle left behind and lines of oil, shut the car down and left it, hopefully it isn't stolen tomorrow :(
I think it's the sump but couldn't see, does anyone know if they are easy to fit and how long?
Also where can I get a good second hand one from?
Is the car okay being towed and where is the tow point?
******* sods law!
Can anyone recommend a good garage in Gateshead?
Edited by ajs_vrs
Get back to that garage take a few photos of offending raised drain-cover, with a small ruler to determine it's exact height from ground level.
After you checked what damage has been done, complain to owner and show photos (copies only) and request compensation/ effective repair.
Take a witness/ pocket recorder to record any conversation for later proof.
I replied in your other thread ;)
Also replied to other thread. Gateshead is perfect for a second hand one.
Thanks chaps, how long would it take a garage too replace the sump is it difficult?
Just going to buy a new one have took pics too
Quite an easy job aslonf as the exhaust comes off. Never changed a vrs one though.
I used to work at the peugeot clinic in gateshead. Brilliant garage, used to work on various cars but ovbs a peugeot & citroen specialist.
Gateshead also has one the of the largest vag breakers around with pretty much every vag you can imagine, vee-dubs. They had a couple ibiza fr's and fabia vrs's so could get a second hand one from there.
In my experience Vee-Dubs is pretty expensive... I rang the other day and they wanted £180 for a set of 4 steel wheels....
I'm pretty sure they'll be able to sort you out with a new sump though.
Firstly, I have never changed a sump on a Fabia VRS.
There are specialist welders that can weld alloy, for a possible repair in situ, after just draining engine oil.
But, when I have been crawling around underneath I have noticed that the sump bolts look very get- at- able.
You would probably need a full sump gasket set, to begin with and, with a new sump would be an opportunity to renew engine oil + oil filter.
Sump is easy to replace all bolts are straight forward to get to easy job with car raised last alloy sump i got for a 130pd bora was £90 ish inc vat so ring and see what a new 1 would cost first
