hatch area lighting
One of the the things I find a bit annoying at night, is that there is no illumination in the luggage area - or is there and I have a bulb gone?
Well, there certainly is on mine, a lamp either side.
Maybe it depends on the year...??
you should do. As above, there should be a light on either side of the boot opening
Mine (2012 car) has lighting in the boot as well
I thought there should be. Must have bulbs gone. Will check tomorrow.
As everyone else says, although I found the original bulbs to be fairly weak. Replaced them with a couple of LEDs, much better. (No need to worry about bulb failure stuff either ;) )
Any links for the led bulbs??
I chucked some ebay LEDs in the boot! Huge improvement for such a small outlay.
with regards to led. You need to remember that the light only comes out from the side so 501's with mostly top mounted led's wont work too well
http://www.ebay.co.u...=item45febd5e5b
....work perfectly. :) :)
They'll also fit in the puddle lights and part of the cabin lighting too.
they do work, ive got ones of identicle design lol
I expect there are better designed ones out there though and more suited to our cars
There have been a few instances that the bulbs are fine, and it was the switch in the boot latch that was at fault. Common problem if the washer pipe has ever come apart and soaked the boot latch with washer fluid.
Certainly worth checking that there is power at the bulb holders.
Mike
Thanks Mike
Checked bulbs today with a battery, and they are both UK. So must be a fault as you suggest. However, I did notice each bulb holder has a diode in series with the bulb - are these known to fail.? Don't have a meter to check them.
If its the switch, where is it located?
Phil
The switch is an integral part of the boot latch
Mike
Hi just checked again. Diodes are not open circuit, so I think the switch theory is the correct one.
When you say the switch is part of the boot latch - is it located in the 'door' part or the rear panel part? I notice on the door part, there is a small cam on the left hand side of the latch mechanism, which will obviously be pressed as the hatch is closed. Presume this could be the switch operation cam.
Now is the switch a replaceable part - or do you have to replace the complete latch mechanism, Mike ?
Ok thanks Mike. I will start looking around for a replacement.
