312mm brakes & gearbox oil change.
Hi , not posted on here for a while as Ive gone over to the dark side ;)
But my daughter has the VRS up in Yorkshire now and is putting on quite a few miles as her work regularly takes her across the pennines.
The VRS has the Audi TT 312mm front brake upgrade - But I have no idea from which Audi TT that would be.
Am i correct in thinking they the same as the Octavia (mk2) VRS ?
I was going to get replacement disks/pads from Eurocarparts. Any other recommendations?
It had Cam belt, water pump, tensioner, aux belt, clutch plate , clutch bearing , DMF replaced in 2011 at 70K miles.
As its now done about 85K miles, Would it be sensible to replace the gearbox oil. If so with which oil?
Not sure on the box oil.
But they'll be off a mk1 TT or mk1 octavia vrs
Pagid have a good rep from euros, make sure to use brisk25 code or pagid30 may be working for 30% off pagid.
For gearbox oil II used
Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic
and Eurocarparts Pagid brakes for 312mm brakes
i couldnt get pagid30 to work :(
Thanks everyone.
FYI ECP are doing a January 25% off at the moment and free delivery - see their website.
