TERKINS Vrs
been having a nightmare last day,hoses keep boosting off everywhere lol
fixed most but one just wouldnt stay on,played a bit and used a clip i found on the floor seems to have worked :giggle:
picking up a whiteline next week so more goodies :kiss:
Terkin,
That pipe you keep blowing off could be because to intercooler pipes can move independantly of each other thus slowly pulling the silicone pipe apart, You could try a humped type silicone joint there as these provide flex and movement which should cure your issue.
http://www.ebay.co.uk/itm/76mm-3-Silicone-Hump-Hose-Bellow-Connector-Turbo-Blue-/290378883461?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439bee2185#ht_1290wt_904
Craig
  • Replies 939
  • Views 83.6k
  • More like get the thing singing again !!! It's now got a new subframe and arms and polybushed and drop links Will have new cooler pipe work Ac removed Timing belt water pump New braided lines
  • He's colour blind, prob looks like a perfect colour match to him. Poor bloke thinks his car(s) are red
  • not much done,other front collie on, little test of my new hoses and bit of painting
cheers for that dude :thumbup: im thinking it may have been clip as its holding for now. link is in my favorites just incase :yes:
been having boost probs!! never wants to go past 19.8psi, and fluctuates like a boss up down up down grrrrrrrrrr so been reading up tons of possibles but finally got a fault code today 16622 so new map sensor hopefully should be well away :yes: need another smoke test to just incase as alot of hoses have come off since then :o
anyway got my cut down fleebay pipe,new coat of black and fitted
just over a week now bit lower
Cut down pipe looks well mate. Your giving me ideas lol.
was always soaked in wheel arch so thought id give it a trim :giggle:
brand new map fitted surprise surprise no difference, thought id fit the side grills for the test drive good job i did as i had a small collision
im thinking keep the side grills,center the fmic better and bring it right forward havent seen that yet :sun:
are you coming along tomorrow for prept?
i had planned to dunno if i wanna show my face in my under powered corpse covered car :bandit:
ah you may as well :)
:giggle: gonna try get a new n75 2moro as that seems to be winning the race so might just be corpse covered :kiss:
Good to see you made it to prept mate. Had a nosy round your car but you were hiding somewhere
didnt wanna been seen next to it :giggle: saw a few back fabias couldn't remember which one was yours :blush:
My Fabia wasn't there. I went in my brothers Octy estate
ah yeah did see that looked good :thumbup:
changed a hose and the n75 clip now reads positive boost,prob still thier new n75 ordered :happy:
boredom can be a good thing!! did this today finally it boosts past 20psi, 22.8psi peak and made slightly more torque on the gauge generally felt better but still not holding boost n75 soon i hope :sun: proper blank is ordered and probably cut the plug off as it looks messy but was just a temp test for today,finally a positive difference guess it was leaking? dunno lol
dodgy pic from prept :giggle:
busy few days went and saw clives new workshop very nice once you get over the small mountains. passed the smoke test for the first time :rofl: had a new fuel pump and alls well or so i thought!!! went to pvs today good day but ended badly :sweat:
Oh no!
i know was right in the middle of showing a range rover sport whos boss!!
You broke it :(
Got to watch these red ones...... They bite :(
Whats up with him ?
lmao i know
not sure yet bud turns over its getting fuel,so fuse maybe all 4 packs blew at once dunno lol super tired, had to wait 2hours nearly to be recovered,had to wait for a low loader lol
Hope its an easy fix mate. It's never easy when your car tries to stab you in the back.
You spend a bit of money on her and she tries to spend more. (oh I might be mixed up with something else) ;)
Best of luck.
Goodluck bud :)
I would suggest you change your coil packs
Problem solved created another prob due to having your power back lol
Not uncommon just a pita
