TERKINS Vrs
i can see me having to do that with my turbo! :( good work! :)
  • Replies 939
  • Views 76.6k
  • More like get the thing singing again !!! It's now got a new subframe and arms and polybushed and drop links Will have new cooler pipe work Ac removed Timing belt water pump New braided lines
  • He's colour blind, prob looks like a perfect colour match to him. Poor bloke thinks his car(s) are red
  • not much done,other front collie on, little test of my new hoses and bit of painting
cheers only took me 3months to get it out :giggle: have you broke yours? or are you planning to lol
I wish I had taken my engine out to re-fit mine. Nice work!
yeah i did think of you when i was doing it,thought it must of been a total arse ache :giggle: :giggle:
Refitting was worse - on my own :D I had some epic bruises on my forearm. I was kneeling on the front of the bay, head resting on strutbrace to support me, one arm lifting the turbo, the other trying to screw in a bolt.
Took a while, and a lot of bad language.
i am NOT looking forward to doing this soon myself!
blimey lmao!! i was just sitting down coffee in one hand ratchet in the other sun beating down nice and casual,did keep going to remove just to find its attached somewhere else lol the turbo to manifold bolts were really loose on mine no effort at all to move
what turbo removal? its piece of cake just ask rob :giggle: :giggle:
All the bolts came out easily. And it's not that hard, but definitely get a mate to help you, would make it so much easier.
Ooooooo
pretty good day!
started by getting one of these from a local briskie
then cracked on refitting turbo,also noticed that when i removed it the tip had been crushed down to about 1cm,does know one else have this trouble? made a slight modification anyway.
then flywheel and clutch,got close with the box had to leave it for another day getting to cheesed off lol
disc are pretty much shot so new ones :kiss:
made this for the brake vac and some more painting
Love the cat photobomb.
Good work Terkin.... Things moving along nicely.
Iv also got a snapped stud in the turbo! Really can't be bothered to get if fixed at the moment! It will be a right pita!
Craig
Craig
cheers :thumbup:
yeah its not fun,mine was blowing and sounded ****e so couldn't leave it any longer! i ripped all the thread off so couldn't use extractor might be easier for you lol.
Good work as usual mate that last bit getting the box on is always the worse! Just keep trying :) all i keep hearing about is turbo studs snapping :(
lol i shall. dont worry bud your soon be part of the gang :D
ok i quit :@:wall::@:wall: just been round garage cleaning some bits,my spiders are stacked one on top of the other,one fell about 5ft great big ******* bang!!
fitted fronts and some braid
progress at last!! gear box is back on and sealed :devil: most of the engine bits are back in to
and then for the first in nearly a month down on all fours :rofl: just to find out i must of ballsed up fitting the coilovers :wall:
quick snap of my new monster along side a standard 2tonne jack and bigger 3tonne
so not to much longer hopefully :rofl:
did this in the dry :rofl:
Looks wrong does that, looks like the bit between the bushes is backwards.
yep correct found that out when i tried refitting :giggle:
right got the front sorted
cant see the sump staying around for long :giggle:
little play with engine cover
Go you :D
Youve got a whole car again ;)
What discs is that ?
I may have missed or forgot ? Is it bigger brakes you have bud
