Cutting out parts of the fog light surround to expose the SMIC
As title who has done this and what did you use? how far did you go? i thought it was just a plastic cover that could be removed.
It is. Just pull it out.
Thanks mate, can i do that without pulling the bumper off?
I want to retain the fog light though, that still okay?
you just grap the surround at each end and pull no need to remove bumpers etc...
thanks
why? if you're running SMIC, surely you're not running big power? it won't make that much difference :)
just a remap i guess its better every little helps.
I assume you have done the pikey arch mod??
I went to town with the drivers side arch liner and cut slats in it with a Dremel to aid air flow
Some people put a small slatted air vent in them too.
And also, do you have the oem airflow shroud on?
It sits directly behind the fog surround and cover
Thanks, ah i see the whole things comes off i think i might ******ise it and retain just the outer section and part closest the fog light.
unfortunately makes very little difference if any
Off Topic,
Can you change the fog light without taking th ebumper off? Im going to get a direct replacement for mine!
Off Topic,
I'm 99% sure you can't. Pain in the arse.
