Manufacturer Recall..
guys im after some info, did skoda ever do any manufacturer recalls on the 06 vRS referencing the engine at all??
any help would be great!
cheers
mine had a misfire problem for ages, its hard to explain when it did it tbh then after it was re-mapped it went away?! now after a year of the remap its slowly creaping back..
BLT hesitation?
Is it the 1800rpm hesitation issue? If so, there is a 14mm gasket fix for BLT engines.
i think so im completly not sure what it is as it seems to be a mixture of most problems described on here, but i do remember reading something ref a gasket fix..?
I have had the 14mm gasket fitted - it doesn't completely fix the issue and still hesitates when cold. I have read somewhere that SEAT remap this out on BLT engines but SUK only do the gasket fix.
http://www.briskoda.net/forums/topic/259603-vrs-missfire-blt-engine-and-no-check-light/
You might be getting confused, recalls are for safety related items where a problem has been identified and are carried out by the manufacturer in conjunction with VOSA and the DVLA. They have to fix a certain percentage of vehicles before they can close it.
A product enhancement is where a minor fault/inconvenience has been identified and the manufacturer will issue instructions to rectify it on a scheduled workshop visit, they won't necessarily write to the vehicle keeper to get them into the workshop.
