Help needed, confusing problem
Hi all
Had this problem for a couple of weeks now.
Fabia mk1 vRS 54 plate
Basically the car unlocks itself and rolls down the windows.
VagCom comes up with this:
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 33 Komfortgerát 0002
Coding: 00066
Shop #: WSC 13765
VCID: 3D7B7BF8376C84F00A3
Subsystem 1 - Part No: Steuerger
Component: t Fahr. antwortet nicht
Subsystem 2 - Part No: Steuerger
Component: t Beif. antwortet nicht
2 Faults Found:
01033 - Central Locking Key Switch; Passenger Side; Unlock
27-00 - Implausible Signal
01038 - Central Locking Thermal Protection
35-00 - -
End ---------------------------------------------------------------------
got to my car this morning and it was soaking inside so Ive had to resort to taking the fuses out for the windows!
but the car is still unlocking itself, but it has bursts of constantly trying to unlock
Any help would be appreciated
Matt
Possible Symptoms
  • Central Locking not working (partly)
Possible Causes
  • Wiring/Connectors from/to Door Locks faulty
  • Door Lock(s) stiff
Possible Solutions
  • Check Wiring/Connectors from/to Door Locks
  • Check Door Lock(s)
    • See Measuring Value Blocks (MVB)
______________________________________________
Are you sure the key is not inside your pocket which is then pressing the button and dropping the windows? this would not however explain why the car is unlocked as it should re-lock itself 60 seconds after it was opened… providing a door has not been opened. :think:
