What make of Dump Valve is best?
As it happens I'm glad this thread is here, I was thinking about buying a forge valve for my felicia, but based on price I think I'll give the compbrake one a look.
tom, the one above is the same as the compbrake, comes with 3 springs, and is just as good, have had all three, and can't tell the difference.
  • Replies 50
  • Views 5k
  • Jase it doesn't mean its rubbish I could make the same as the forge on my Cnc to the exact same tolerance if not better but wont have forge on it does that make it rubbish ??
  • I got mine off the compbrake ebay ad, try their website Sent from my Galaxy S3, not a Crapple!
  • yup, spot on advice!this is identical to the forge ones, and comp brake ones, its just a milled bit of ally after all as clive said.It works as well as the forge or compbrake without the name..
£35 that's a bargain.. at the end of the day it's a piece of metal with a spring inside, what can go wrong with it....
it seems to be machined very well, so my thoughts exactly!
Compbrake one came with 2 springs
Stay away from the forge splt-r i bought 1 for my 1.8t golf and there rubbish to be honest. Id go for a compbrake or even i think creation motorsports do 1 aswell
Thanks for the advice/coments guys.
Are we saying that the best road to go down is Compbrake then?
no, ebay jobbie with 3 springs, its better value than compbrake and the same..
Ah. Cheers Terkin.
Whats wrong with the one i linked to??
its not recirculating ;)
Its atmospheric...you need RECIRC
Cheers guys.
I know im a pain in the arse but im just a tad confussed. My old Scooby STI was so much more straigh forward when it came to DVs.......
My mate hate had on 53 plate VRS and had a Baileys VTA on it and didnt have any issues with engine lights or rough idleing etc. Strange.......
If you fit the £35 jobbie off ebay does the engine cover still fit? Or does it have to be removed?
Sent from my iPhone 4s
Theres nothing complicated about it m8 these engines need a diverter valve not a vta valve , but at the end of the day its your car so you can do what ever you want to its all about personal prefference , every one here will give you advice and help from past experiances and that is to fit a diverter valve .
If fits, the top vacuum pipe is a tad close but it fits.
Thanks mate. As long as it fits. Engine cover makes it look neat so plan to try to keep it on
fits without modification
If you get one without lots of springs, you can uprate it slightly with a couple of BIG washers. :D
  • 6 months later...
Ive had r-tech stage 1 map,which spring do i use or does it not matter?
Standard one
Hi
sorry for being thick but is the standard one the yellow or red one or does it come with one already installed thats the standard one??
Im referring to the ebay one in the earlier post.
Edited by Jimmy C
No standard oem dump valve is best
ok, are the ebay ones no good then? ill just order an oem one if thats the case.
Get the latest one from audi mate. 06A 145 710P  theyre about 30 quid. T
