VCDS help
Hi all,
Looking for some guidance :)
I tried increasing the steering weight but when I changed the value and saved it kept reverting back to the original setting?
I also tried increasing the idle speed slightly (for fun) and upon clicking test and save nothing happened. I could increase the values and save but no end result.
Lastly, turning down the EGR. I was unable to fine the section 'ECU' which is apparently needed for this?
On the plus side I got the locking beep and changed some other stuff too :)
Any help much appreciated :)
Jordan
I want the locking beep too :(
I put locking beep on mine the other day and took it off straight away... Its bloody loud!!
Just found out my leon has a different steering setup and i cant lighten my steering :(
Think mine is hydraulic and fabia is electric :(
You need an s3 rack!
Plus 1! It's a lot louder than i had expected. Ill see if I can put up with it for a few days! Lol
Have you found the section for turning down the EGR flow? http://forums.tdiclub.com/showthread.php?t=271955
Have a read a few posts down. I think I was in that last night and thought it was idle speed lol Ill be able to do this successfully now!
