Interior lights
Is there a way to make the interior lights come on after turning the ignition off? Just ask as all my previous cars did this and i miss it.
Thanks in advance!
My elegance does that when you remove the key
Mine too
Mine does. Do you mean once you've turned the engine off but before the key has been removed?
I find it annoying that when you switch the front light on the rear doesn't go on. ( taxi driver )
So having my mate wire two super bright led strip lights into the back, wire it to the rear light then a seperate switch on the dash to control all rear lights!
G
I converted my front interior lamp unit switch so that when switched on (with doors closed) the rear lamp comes on too :)
I checked last night and the light only comes on once the key is removed and the door opened... is this VCDS tweak that i need to beg/plead with someone to activate?
thanks!
Anyone have any thoughts on if this is a tweak that can be done through vcds please?
Interesting. How did you do that?
I don't see any option on VCDS about this.
thanks!
it should do it anyway.
Have you got maxidot? Might be in there
No just the basic screen thingy, oh well summer approaching i wont miss it (as much!)
I dont have maxidot and mine comes on ( front and rear) when i remove the key.. even with the doors closed.
Bit of topic here. In fabio's octy picture, his indicators are both on like side lights, do you still have the drl's runing with them on.
are you talking about the pic in my signature? Sorry I'm Italian so maybe I misunderstand some technical words. With indicators you mean orange turning lights? They are lit cos I turned on emergency lights
Sounds like you might have a fault someware tbh
I did wonder if it was to do with the ignition barrel, everything else seems fine....
