Bluetooth causing me no end of misery!
I;ve accepted defeat, my BT works, people can hear me it displays phonebook on columbus job done.
Does the 1Z0...729B (metal cases) have the same connector as the other modules (plastic cases)?
If not, I'll have to give up as my looms are hard wired together...
Very true, its hardly an issue!!!
1k8 is no good as it doesn't display on the radio
5N0 will but only works with a small number of phones
if you want the full package, it has to be a fiscon kit
1Z0 uses the same plug, so a direct swop is possible with all the vag modules
