G201, Basic Settings in VCDS question? Help!
Hi everyone,
well leading on from this thread http://www.briskoda.net/forums/topic/267685-2007-octavia-pd170-brake-switch-help/
I found I needed to do the basic settings to clear the ESP light on the dash. I have now been left in an awfull quandary as my NCT retest is Tuesday afternoon and I cant get the code to clear....HELP! I used Ross techs guide for the blocks and figures settings but keep getting the same results below. Its my first time using VCDS so look carefully as I may have made a schoolboy error!!!
So G201 Brake pressure from measuring block 005 gives this result
So into basic settings I go...measuring 066 as per Ross tech gives this screen
Then clicking on ON/OFF/NEXT gives this screen
What do I try next....am desperate to get this retested on Tuesday!
Mike
Agree with FF. If that was the reason for changing your brake switch (your previous thread) then unfortunately you have headed down the wrong route and you need the ABS repair kit.
Cheers guys, here is the error below.
That isn't related to your brake switch, you need the ABS repair kit.
Thanks fella, my fears come true!
