Retrofit cruise control Fabia 2
Does anyone in Northwest England offer fitting of cruise control or know anyone who you could recommend for the job?
Martin
You can give awesome GTI a ring, I think they offer a supply and fit for about £250 ish. They have an excellent sales team and will do the best deals they can for you.
They are based in Irlam Manchester :)
Hope this is of use to you
Sean
Sean
yep spot on been there and great people to deal with.
Thanks very much. I will give them a try tomorrow.
Martin
What age Fabia 2? I charge
<2010 £180
2010> is £280
However I have found the 2010> kits are wrong for some applications.
<2010 £180
2010> is £280
where are you based?
<2010 £180
2010> is £280
2009 Fabia 2. Where are you based?
Martin
will also depend on the electronics module fitted, some need to be replaced
Mine cost £350 at the stealers. I meant dealer lol
what is needed to fit these? I take it its not just a case of swapping the left hand stalk and coding this time like the MK1
Stalk set (both stalks)
wiring loom
Some cars with low version BCM also need that to be changed
How can you tell what BCM is required?
I'm fairly sure your Vrs has one that supports Cruise, it is on lower spec cars where the BCM needs changing
any ideas for part numbers for these ?
