clutch pedal noise?
hi folks just noticed an annoying creaking noise when I press/release the clutch pedal, does it some days and not on others???? anyone come across this before???? cheers :)
Yeh mine used to do it, then one day it just stopped. Saying that it was around the same time I changed the brake light switch and it was just about solid, really difficult to depress
Sent from my GT-I9300 using Tapatalk 2
the pedal feels fine and clutch is working fine, just really strange as its intermittent (and sooooo annoying) ??? more of a clicking noise I guess.
Could try some wd40?
Have no idea why mine stopped, think it's strange that it did around the time I changed the switch on the brake pedal lol
mine creaks too, must be somewhere on a linkage
Mine does it too. And again its intermittent. Seems to do it more so in hot weather tho.
cool thanks chaps, feel better knowing others do it as well :) happy days :)
WD40 is your friend here, remove the cover thing above the pedals (2 torx screws) & smother the pivot & master cylinder rod with it.
Mine does this too ! Thanks guys wd40 to the rescue :)
it isn't catching on the plastic covering which clips in above the pedals is it?
