Top boost pipe replacement DIY :)
What's the quality of these coupler like?
  • Replies 324
  • Views 78.6k
  • All made up ready and will be installed moz morning
  • I think it would be important to have a ribbed end on the metal pipe to prevent the silicone slipping off. failing this use a glue or sealant?
  • Yes thats exactly it as I have an egr delete so didn't need the type 'b' coupler, think the 90º bend was 51-57mm? Will have to double check.
I haven't had any issues with the coupler itself and it seems good quality. :thumbup:
Does anyone know which connectors we use for the small lower intercooler pipe (90 degree one)
I can't remember mate it's on this thread somewhere. Where are you from as I have one lying around you can have for free if your near me I'm from glasgow, I've changed to a front mount cooler so have no need for it :)
Yeah it's an original one mate your welcome to it if you want it, if any one is looking for the connector to connect to the top of inter cooler I have one off ebay they can have for free too as I don't need it anymore
Does anyone have updated links for everything needed for this?
thanks!
Thanks. I'm looking to upgrade the connectors as the oem ones are ****. I just need to know what billet connectors to use for the lower IC connectors!
Ebay item numbers ive found so far (top boost pipes with egr delete)
Upper IC billet (Connector A) : 150802992992
45 degree silicone pipe: 290470155679
90 degree silicone pipe : 300458865210
I cant find the 70 degree mandrel bent pipe.
I cant find the 70 degree mandrel bent pipe.[/color][/font][/size]
Try emailing or phoning pepper performance for these.
Hey mate if you don't need the one for the top of the intercooler I'm in Edinburgh and I'm just about to do this mod I'd be happy to give you £ for it if you would be happy to post it
Edited by Andy5co
+1 Dann2707,
This should be turned into a GB - am sure there would be a lot of interest!
Im after the whole lot if anyone can help..
Thanks,
adil
In the original post mate I've listed everything you need could try typing them back into ebay? See if any other sellers have something similar to the parts needed
So at the weekend I thought I'd fit my top boost pipe as everyone is aware the skoda ones are prone to boost leaks
For anyone that's interested I put together a list of the pipes etc needed to make your own also remember that the silicone hoses do need bits cutting off each end to fit hope this helps people that want to do the same :)
1x type a coupler
60mm clip side outside diameter (o.d) male coupling, suitable for a 51mm internal diameter (i.d) hose.
1x type d coupler
64mm clip side outside diameter (o.d) male coupling, suitable for a 61mm internal diameter (i.d) hose.
Both from this seller - http://www.ebay.co.uk/itm/VW-AUDI-SEAT-SKODA-TDI-FSiT-ALLOY-BAYONET-BOOST-HOSE-INTERCOOLER-HOSE-COUPLER-/150802992992?pt=LH_DefaultDomain_3&var=&hash=item231c8f0f60
2" 51mm O.D stainless steel bend - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320782541076
1x 45degree 51mm internal silicone hose. - http://www.ebay.co.uk/itm/290470155679?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
1x 90degree reducer 60mm to 51mm silicone hose - http://www.ebay.co.uk/itm/300858977454?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Also need jubilee clips which I bought from my local BandQ
1x70mm jubilee for egr 90degree hose
3x60mm jubilee's for the rest
Please feel free to ask any questions or anything
Hope this helps :)
this is very helpfull, do you know if this will be the same for and egr delete and forge intercooler? :s might be a silly question but got the intercooler at home and want to replace this section of the pipe work.also how do you know if the stainless steel bend will be long enough to meet both ends? many thanks Sam
thanks!
+1 Dann2707,
Thanks,
adil
All the information you need is in the 1st post, so just type that info into eBay to find the updated links of the items needed. :wonder:  :thumbup:
If you look in the Group Buy threads, i think there was something trying to be organised in there for the top boost pipe.
Just made up a top pipe for mine to join up to the Forge piping.
Well pleased with the outcome :)
57mm Darkside EGR delete shortened down,57mm hump hose joiner,57mm 90deg alloy bend,57mm alloy hose joiner welded to the 90deg bend,45deg 57mm to 51mm reducing elbow to match the Forge pipework,51mm alloy hose joiner.
Anyone after making up pipework from the turbo to cooler Forge do a silicone hose like below,couplers for the turbo are available from Forge/Darkside or I think you could use the standard one if you cut the clamp off it ;) but the standard one is very small internally.
Turbo couplers showing the different size inside diameters,Forge on left,Darkside in centre and standard on right:
Coskev I'm looking at replacing that turbo pipe myself, do the couplers come with the pipe? Cheers
Very nice! Have you got a link for the silicon pipe coming from the turbo?
Mine did as it was the full Seat Sport style kit from Forge,I know they deffo list the couplers seperate on there website,give them a ring is best bet about pipe :)
Or message them on here ;)
As above soz,it came with the cooler as a kit,contact them would be best bet :)
Sorry yo be a pain, but what size is the turbo coupler? Gonna bell forge but don't wanna sound a 'tard then ask for discount :P
Allard 57mm top boost pipe from group buy.
Posted Image
Posted Image
Fetched my couplers yesterday
Going to try and dry fit them and see how they look
Just thinking......
Could you use hose joiners to make up the boost pipe?
