Recommend me an independent garage near Bracknell or Reading
Hi,
I'm looking for a recommendation for an independent garage in the Bracknell/Reading area. I've used main dealers before and good to really bad experiences (one actually damaged the car and denied everything, basically said tough!)
I'm after a 148,00 mile service, investigate a noisy clutch bearing (eek!) and a wobble from the front wheel at motorway speeds. Oh and its an Octy Vrs 54 plate
The speed wobble was introduced by a main dealer and trashed tyres, but I had it laser tracked and found they'd knocked the 'toe in' right out and the tracking was out. I got that sorted, the tyres do OK now, but the wobble is still there.
Thanks in Advance,
Davvers
Clives in workingham
He is cntuning
Wobble is probably just wheel balancing. Noisey clutch is probably failing DMF!!
Clive @ cntuning
Storm Developments in aldermaston.
VAG specialists, they also do supercharging.
I have used them for my vW T4 and octavia TDI estate.
Thanks All,
Autotechnic are going to have a look on Tuesday.
I'll let you know what they find.
Davvers
Clive cntuning! Taking mine to him this weekend to get a few bits done. Very helpful guy! He's owned and done up a few octys before.
  • 7 months later...
Ended up getting serviced and some extra work, but not anything else.  New clutch etc was recommended, but given the age and miles on the car did seem worth it. Eventually the noise went away !
J-tech Automotive in reading!
CN tuning in Wokingham!
