Anyone tried these yet?
Don't bother. They will be dim and the LEDS will burn out due to overheating.
I replace my dipped bulbs on average each year. I'm getting quick at it now and some white grease added each time makes the unit come out easily.
At the moment my OSF dipped bulb blows on average once a month, I have tried cheap ring to last night night breakers, wanted to fit HIDs but the lamp connection is different, it does not have the wire clip and the bulb holder just turns a quarter turn then you just pull the bulb out
as i said in your superb forum post. They will not be bright enough, you wont be able to drive at night with those in the car
If its blowing once a month its either an earthing problem or you are touching the bulbs during installation.
Edited by Web Ferret
so you've seen proof how bad they are then :)
