Sump plug issue
I've services my car today and while I was re-fitting the sump plug it failed to tighten completely. While I can't move the plug with my fingers it will move with little force using a socket.
After looking on here people seem to think that a replacement sump is required due to the alloy sump thread giving up. Is this the best option? Are there better after market sumps that don't have this issue?
Also would the car be OK to drive? After sorting out the oil levels I've left the engine on tick over and couldn't see any leaks.
You can get sump thread repairers with a slightly larger sump plug and a tap to cut a new thread I believe.
You can also get it Helicoiled, you need to remove the sump either way.
or buy a genuine steel bottomed sump. the stud screws into steel so a lot harder to damage threads, you will also have more clearance under the car as they are low down. ideal if your car is lowered and with the bottom being steel harder to burst.
Is there any current risk of leakage?
It will probably leak when the oil gets hot and thinner. The amount would only be small and you should be ok if you keep an eye on the level
Sent from my LT26i using Tapatalk 2
Yes, there is a serious risk that the plug will just fall out if you drive it, then it'll just spill all it's oil and wreck the engine in moments.
Don't do it.
Install thread insert like already suggested and buy fumoto qwikvalve so in the future oil draining by flip of a handle.
Well a true Helicoil kit is around £55 on Machine Mart - Link, a cheaper kit off eBay is around £24 Link
However a steel sump is around £30 (Topran off eBay) but I'm unsure which to get. Does the Fabia have an oil level sensor?
Mine didn't have a level sensor, it died after 4 days of ownership as the garage failed to put my sump plug back in properly! Do not take your sump plug for granted :(
I wouldn't use that cheaper kit as it's just oversized thread and plug. How about bringing sump to machine shop and let them install thread insert. Shouldn't take more than 10 minutes and wild guess 15-20£.
Or buy that steel one.
TBH if I have to take the sump off either way then I may just get a steel one and hopefully not have this issue in the future. Is it confirmed that the vRS 13 PD engine doesn't have an oil sensor level?
Pretty sure mine does, theres certainly a sensor and wiring in the bottom of my sump anyway, though mines an 04 vrs
my 04 has an oil level sensor
any link to this? it sounds very cheap..
a genuine steel bottomed shallow sump would be around 120
Did you fit a new sump plug or re-use original?
I re-used the old one as normal but this time I think I over tightened it. :(
The 'normal' thing to do is replace the sump plug on these engines.
D'oh - I'll remember that in future.
Does anyone know a place that sells Steel sumps as all i can find are alu ones.
Also is the sump plug thread m14 1.25 or 1.5?
Edited by wilsonian
Yup re-using old one and over tightening it (by the sounds of it you've changed oil previously) you've cream crackered your sump!
Helicoil or new sump required along with eating less spinach
Think in future its a torque wrench all the way :)
Just to confirm - does anyone know the pitch of the tread for a sump plug? I've seen kits with 1.25 & 1.5 listed :(
1.5 it is.
