Removing front seats
I'm wondering if anyone can help?
I've not got any of the correct sockets that will help me remove the front seats. I'm wanting to give it a good clean out and there is so much rubbish the hoover can't get!!
Can anyone provide me with the correct size of socket that I would need?
Thanks in advance :)
Edited by kevvrs_130
Its a good idea to replace the bolts unless you want to push your luck too.....otherwise could become a bigger job than you first think
http://www.ebay.co.u...<br /><br /> thats a universal tool for removing nuts , bolts , and pretty much anything else :)
Edited by Holmesie
As an alternative to a splined bit you can get them out with a good quality 13mm splined socket .I know the outside is round but I used a Draper Expert 13mm splined socket on one seat bolt ( always the last one ) which refused to budge & I stripped the internal splines. It was tight, but I hammered it on & the bolt came out easily . The socket wasn't damaged either which is a bonus.
I'm assuming you can just replace then with standard m10 bolts too??
Yes, but difficult to get a socket over to tighten because of the seat rails.
Ahh yeah, so it would. Thanks
Does anyone know if this would be a suitable to replace the bolt?!
eBay number: 380640672739
Jay
