Various parts forsale (Gauges, Amp & Subs and 18" Wheels)
As title I have the following parts up for grabs.
I decided I don't need 2 modified vRS's so the road car has been returned to almost standard, and these parts are now avaliable.
Swoosh Boost and Volts Gauges in Triple gauge pod to fit above / under stereo
These are electronic smoke faced gauges, so when turned off you they go black, and the pod has been wrapped to match the carbon effect of the stereo trim.
£95
Centre boost gauge not included.
Hifonics Brutus 1200w Amp and Twin SNG Audio 12" Subs in Box.
No idea of value, fits nicely in the boot of the vRS, has all amp wiring included.
£100 (collection only as very heavy)
T2eC16RHJHIE9nyseHP1BRDQStO3g60_57_zpsba
18" RS4 reps (5x100) 18"x8" ET35 with as new 225/40/18 tyres fitted.
Would rather swap these for some other wheels that will clear brembo calipers though, as i'm fedup with fitting spacers everytime I put road wheels back on my car.
This picture shows how they sit without spacers fitted as this was when I had the tarrox calipers fitted.
Forge TIP (BLUE)
In good condition (there are a few marks on it but not noticeable when fitted), the DV and PCV outlets have been cut down as they were too long, but this isn't noticable when fitted.
£SOLD
Tarox 6 pot front brake kit
The calipers are in the rare metallic Green, so go very well with the standard rear brakes, the front discs are in very good condition, and are what Tarox call the sport Japan discs, they are Grooved and drilled 323mm, and there is plenty left on the pads too, Goodridge braided front hoses and all bolts and brakets are included.
£SOLD
Forge 006 dv (silver)
This is only a couple of months old, it has a few minor marks on it, but they would prob polish out.
£SOLD
Apexi AVCR boost controller
Probably the best electronic boost controller in the world, comes complete with all wiring and sensors, and I even have a copy of the instruction manual to help you get it setup, I will also include the ashtray lid if required.
£SOLD
Jabbasport Induction Kit with Heatshield
Comes with K&N filter (needs a clean), maf adaptor, adaptor and K&N filter for SAI pipe, and the Heatshield (the heatshield has a couple of small holes where the AVCR solenoid was fitted to it, but they have been covered with 2 small stickers and won't effect the performance of the heatshield).
£SOLD (£230 new)
Forge Front Mount Intercooler kit.
This is the complete kit with crashbar (the crashbar has been drilled to allow more air to the cooler, but it has not been cut, and therefore it still has it's strength), There is also an adaptor to take both sizes of map sensor (map sensor not included). These are the easiest intercooler to fit to a mk1 octavia vrs.
£SOLD (£730 new)
Full Stainless Exhaust System (Turbo back with 200cell sports cat).
200cell sports cat which will pass an MOT (as it only did so last month), with custom cat back system, non resonated centre box (cobra), and standard tailpipe fitted on the end, for that standard look, very very well made system that bolts together with flanges rather than slot together, and very quiet whilst still giving a nice burble and also very light for the size of it.
£SOLD (sorry can't split as the system won't bolt to a standard downpipe)
If you want any pictures of anything specific please ask and I will sort them as soon as possible.
All prices are FIRM and + delivery, no offers at these prices please, obviously collection is prefered due to size and value of most items.
  • Replies 68
  • Views 8.5k
  • Lloyd55vrs
    Lloyd55vrs
    Oooo my brakes i need lol Feck :(
  • Yep after a couple of hours of looking around and cross referencing pad numbers. It seems they use the exact same pads as the LCR brembo's too So DS2500 = FCP1348H, DS3000 = FCP1348R What slowed m
  • Replied You don't really need a new turbo, find a used one instead and get the brakes Only if someone wants the gauges without the pod, otherwise I don't want to split i'm afraid.
Pm sent mate
OH MY GOD.. I want those brakes! But budget only stretches for my new turbo :(
GLWTS :)
Would you sell the boost gauge pod separate to the gauges if so how much posted to Portsmouth thanks lee
Pm sent mate
Replied :)
GLWTS :)
You don't really need a new turbo, find a used one instead and get the brakes :D
Hi mate, what size is the TIP?
Standard size for K03s and standard maf.
Feck :(
Its not one of the bigger ones that have been introduced recently then? The 75mm sort of size?
No, but the forge ones are not restrictive, I have a forge 1 on my track car also and thats good enough for 250bhp / 303lbft.
Ok all pictures should now be working (hopefully).
Hi whats your location Plz
cheltenham, gloucestershire
So with could afford those fecking brakes :(
Hmmm who could i mug lol
How are they for replacement discs ?
Specific tarox
Or is it another vehicle disc n pads they use ?
They take LCR Discs and pads Lloyd.
If they're the B30 kit anway
lol :D
Specific tarox
The discs are normal LCR discs (the Tarox sport japan discs are mega money, for them to zinc coat them, and then drill and groove the discs), but you can fit any LCR discs.
The pads are made to fit the caliper, however there are options avaliable so you won't have to stick with Tarox pads if you don't want.
It is the B30 kit.
So any funky lcr disc goes on then
Seems yellow stuff is available for some tarox kits
Hmm.... How to fund them :)
Yeh any LCR discs will do.
For pads there is plenty of options, Ebc, Pagid, PF, DS2500 and DS3000, I expect carbotec do something also.
So on tarox site it says sp0331
Is it these then
http://bit.ly/12oVgaz
Having checked on the Tarox website, it would seem they are the correct pads (the HUGEEEEEEEEE 16 pot B400-GT16 calipers use the same pads all be it 1 set per caliper).
So i now just need ur brakes lol
:D
Im guessing theyd come with everything to fit them
:D
Everything needed is included, except brake fluid :)
Does anyone have a like for the good frodos that fit ?
Just nosing at prices of spares lol
And talking nice to my wifey ( not working well at mo )
I neeeeeeed these lol
