How to get 'Think Blue Trainer' for Citigo & Mii...
<?xml version='1.0' encoding='iso-8859-1'?>
<Settings>
  <Active>1</Active>
  <VehicleIdentificationNumber>WVWZZZAAZFZ696969</VehicleIdentificationNumber>
</Settings>
and Change the Vehicleidentificationnumber to your own VIN
  • 1 year later...
  • Replies 51
  • Views 46k
  • Add a folder to the root folder called branddevice.reg and when you unplug and it restarts you can select make again
  • What does the "Think Blue Trainer" do?
  • pixel_viking
    pixel_viking
    Tells you how economically you are driving... the more blue rings the better - gear shifts and general fuel economy.
January '21... just got a second hand one of these for my wife's Citigo but it was showing the VW branding which i managed to clear by doing the following:
* Connect to PC via USB cable - NAVIGON hard-drive appears - open this.
* Create a simple text file in the root and rename it branddevice.reg
   (make sure you're computer is showing file extensions or else you might actually make a file called branddevice.reg.txt which probably won't work.)
* Reboot! It should then ask you to connect the device to your car whereupon it picks up the make and model automatically and asks a few other setup questions.
The UserSettingsDevMode.default file didn't exist on this device.
